1991 Pontiac Transport low power
1991 PONTIAC TRANSPORT
154,000 MILES • 6 CYL • 2WD • AUTOMATIC
GENEMIKEGARYBOY
What causes my 1991 Pontiac Transport van to slow down on up hill grades
Mar 24, 2010 at 5:36 PM
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 23, 2010 at 1:07 AM
