1997 Pontiac Trans Am
1997 PONTIAC TRANS AM
80,000 MILES • V8 • 2WD • AUTOMATIC
BEAMER21485
car is over heating! radiator is not leakin anywhere but have to add a little fluid to it dont have to add much but seems like when trying to crank the car is when the fluid gets low double checked to see if it was leakin anywhere and no leaks on the ground
Jun 6, 2010 at 1:13 PM
Check and test thermostat, also if the radiator is clogged and water pump circulating coolant if all okay-could be airlock try bleeding it don't work -block and pressure test it
Jun 7, 2010 at 5:13 AM
