1995 Pontiac Trans Am backfire
1995 PONTIAC TRANS AM
125,000 MILES • V8 • 2WD • MANUAL
CHEVYRACING317
I was wondering what causes a backfire through the intake and cause the vehicle not to start. The motor is a lt1
May 26, 2010 at 3:51 PM
Ignition timing could be off and wrong firing order/lean and rich mixtures-Do the basic stuffs below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors and computer. Note: If it doesn't apply disregard it
May 26, 2010 at 5:25 PM
