1989 Pontiac Trans Am fuel pump problems
1989 PONTIAC TRANS AM
REDBOY66
  • 5 POSTS
Electrical problem
1989 Pontiac Trans Am V8 Two Wheel Drive Automatic
put a new fuel pump in the car and theres no power to the plug. how do i fix it
Mar 24, 2010 at 7:38 PM
Check and test the fuel pump fuse and fuel pump relay
Mar 25, 2010 at 5:16 AM
REDBOY66
  • 5 POSTS
[quote="rasmataz"]Check and test the fuel pump fuse and fuel pump relay. i bought a new fuel pump relay too. what else cant i check
Mar 26, 2010 at 10:26 AM
Check and test the computer controlled of the fuel pump relay
Mar 26, 2010 at 12:24 PM
REDBOY66
  • 5 POSTS
[Check and test the computer controlled of the fuel pump relay/ ok how do i test the relay it new too. but i jumped across the fuelp/ oil pump switch and got power ! so what would be the next check thanks redboy66
Mar 27, 2010 at 10:07 PM
You will have power for 2secs before the fuel pump relay de-energizes-you lose power here during cranking the oil pressure switch powers the fuel pump when oil pressure is above 4psi-Check/Test/Replace the oil pressure switch.
Mar 28, 2010 at 5:02 AM
REDBOY66
  • 5 POSTS
hey thanks alot for ur help working great, but one more question for ya . have the car running but runs rough . new plugs rotorbud and cap wires. what could it be now. could it be the maf switch
Mar 30, 2010 at 11:19 PM
Check the fuel pressure if its within specs if okay clean out the idle air control valve and see what happens. This can be a bear to find.
Mar 31, 2010 at 3:45 PM
