1985 Pontiac Trans Am oil leaking-under pressure
1985 PONTIAC TRANS AM
160,000 MILES • V8 • 2WD • AUTOMATIC
LINDA MASKE
Would a bad(blown)head gasket be the cause of an oil leak? 305 ci V8!
May 23, 2010 at 1:14 PM
CARADIODOC
  • 34,306 POSTS
Hi Linda Maske. Welcome to the forum. A corroded head gasket could cause an oil leak, but leaking coolant would be more likely as it is under pressure once the engine warms up. There are no passages going through the heads with pressurized oil, only drain back passages. Leaking valve cover gaskets are more common. Oil always runs down, so look for the highest point you see oil on the side of the engine.
caradiodoc
May 23, 2010 at 2:15 PM
