Is the Actuator Rod suppose to display a back and forth motion to relatively push the Ignition Switch spring loaded slide section as the Key Lock is turned to the Start and released to the Run position or returned to the Off position?
If so, what can I do to fix the problem, if the Actuator Rod is not moving back and forth relative to the Key Lock Position?
May 31, 2010 at 7:04 AM
