2005 Pontiac Sunfire
2005 PONTIAC SUNFIRE
148,000 MILES • 4 CYL • FWD • AUTOMATIC
MISER
Thank you for your response to my first question. The car has air conditioning. Should the fan be running before the car warms up without the air conditioning on? Is there a temperature sensor at the engine block or else where that controls this?
Oct 21, 2009 at 8:51 AM
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_sunfire_cts_1.jpg
The cts can cause an issue, I wouldn't think it would cause the fuse to blow? Fan shouldn't run with cold engine, normally. Maybe there is a fan request for some reason, you might check for codes. I still don't think that would cause the fuse to blow?
Oct 22, 2009 at 12:36 PM
