2004 Pontiac Sunfire Fuel Pump
2004 PONTIAC SUNFIRE
112,000 MILES • 4 CYL • 2WD • AUTOMATIC
ROCKO
About a year ago my car stalled and I had to replace the fuel pump. Recently, my car has been showing similar signs of the same problem ( ie. not getting up to speed when I press down on pedal, not starting right away, feeling jerky while driving ) I was told back when I replaced the pump that it was because of keeping the gas levels too low for long periods of time. Is that true? I will admit I may keep the levels a little on the lower side. To avoid having to replace the pump again, is there anything that I can do? Or at least to keep it from getting worse?
Feb 11, 2008 at 7:56 AM
BEN-2CARSPROS
  • 7 POSTS
its like the doctor sez, take your medicine as instructed, same rule applies here. fill her up..
About a year ago my car stalled and I had to replace the fuel pump. Recently, my car has been showing similar signs of the same problem ( ie. not getting up to speed when I press down on pedal, not starting right away, feeling jerky while driving ) I was told back when I replaced the pump that it was because of keeping the gas levels too low for long periods of time. Is that true? I will admit I may keep the levels a little on the lower side. To avoid having to replace the pump again, is there anything that I can do? Or at least to keep it from getting worse?[/quote]
Feb 24, 2009 at 2:40 PM
