2003 Pontiac Sunfire Service Light On: Left Headlight - Hig
2003 PONTIAC SUNFIRE
45,000 MILES • 4 CYL • 2WD • MANUAL
ANNOYED08
Okay here's the problem: today when I started my '03 sunfire I heard a ticking sound and then the 'service' light came on. I got out checked around my car and noticed that my left headlight was out. I tried it on both the low and high beam and neither work. So, I then checked all my fuses, none are burnt out...I immediately assumed that my lights were burnt out so I bought new bulbs came home and put them in...to my surprise this didn't fix the problem. Does anyone have any answers as to what may be the problem/pontential fixes? I'm assuming the dealership will charge a couple of hundred to fix this issue so I would like to try to take it into my own hands if at all possible. Thanks.
Mar 18, 2008 at 3:55 PM
MASTERTECHTIM
  • 4,750 POSTS
you need to get a test light and test to see if there is a power source and a ground. you must be missing one, then track down the wire and look for a open, i would look at the ground because they share the same ground but different power source.
Mar 18, 2008 at 4:27 PM
