2002 Pontiac Sunfire Turn Signal
2002 PONTIAC SUNFIRE
SWIFT79
  • 4 POSTS
2002 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
My back right turn signal dont work. In the dash it blinks fast. I have replaced the bulb and checked all the fuses. All the other lights are fine except one hedlight is dimmer than the other. Im just really dumb founded with this and want to know what it can possibly be so it can be fixed and I dont get rear ended with my children in the car
Apr 24, 2010 at 7:20 PM
BLUELIGHTNIN6
  • 16,542 POSTS
the socket that the bulb gets inserted into may be corroded or just bad, also check the wiring to ensure it is connected and not broken at the bulb housing.
Apr 24, 2010 at 8:14 PM
SWIFT79
  • 4 POSTS
My rear brake light also isnt working. HELP
Apr 24, 2010 at 8:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
oh thought you said all were working..so neither brake lights work either? may have wiring issue somewhere at one of the brakelamp assemblies. need to inspect that wiring very good. also test the brake light switch, located under driver dash near brake pedal
Apr 24, 2010 at 8:27 PM
SWIFT79
  • 4 POSTS
[quote:185b4a3e5c="bluelightnin6"]the socket that the bulb gets inserted into may be corroded or just bad, also check the wiring to ensure it is connected and not broken at the bulb housing.[/quote:185b4a3e5c]
Okay so i replaced the socket because yes it was corroded and all the wiring looks fine but guess what now NONE OF THE TURN SIGNALS WORK NOW nor does the hazard lights .....advice please
May 2, 2010 at 5:58 PM
BLUELIGHTNIN6
  • 16,542 POSTS
did you test out the stop/hzd fuse in the instrument panel or just visually inspect it?
May 3, 2010 at 2:40 PM
