every light works on the vehicle except the reverse lights. i think its the neutral safety switch but i dont know how to repair it.
Oct 27, 2009 at 7:31 PM
CERTIFIED EXPERT
Turn key on -check fuse turn-B/U fuse 10amp in I/P fuse block if okay At the park and neutral switch on top of transaxle check for power at pink wire got power jumper it to the light green wire light should come on if not check the ground circuit below left front seat
