2000 Pontiac Sunfire green fluid from water pump
2000 PONTIAC SUNFIRE
BLUEOLDS
Engine Cooling problem
2000 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
There is a green fluid around the water pump. The antifreeze is pink. What could it be? I had the A/C serviced 6 months ago and I just started to get this green dripping onto my driveway.
Nov 23, 2008 at 8:46 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Has to be coolant. Did the A/C shop flush the coolant system? If not, and they just added pink coolant to the green or yellow coolant then it is going to look green.
I suggest having your water pump replaced before it completely gives out and overheats the vehicle.
Nov 23, 2008 at 11:41 PM
