[quote:34cfcbeaf8="blackop555"]sounds to me that the car is releasing gas pressure due to a damaged fuel line or a bad fuel pressure regulator![/quote:34cfcbeaf8]
Heres whats up, I just put a new engine into the car, and I know its not the engine because it started fine in the other car i took it out of. When I hold my key in the start position for 5 secs the car starts fine and like I said before if the engine is still warm it starts right away. I had a mechanic look at the fuel pump and the fuel filter and both of those were fine, if I did fix the fuel line or the fuel pressure regulator how much would that cost, also how big of a problem is this... is it something i should get fixed right away?
thanks!
Dec 22, 2007 at 7:06 PM
