1998 Pontiac Sunfire Starts, won't run. Dashboad warning li
1998 PONTIAC SUNFIRE
15,000 MILES • 4 CYL • FWD • AUTOMATIC
CHECKERBUTT
Car will run while starter is enaged. Dies immediately after Ignition switch turns to "run" position.
Dashboard warning lights do not illuminate at ANY TIME. (No Bulb check upon start). What controls the illumination of the lamps when the car is first started???
PCM reports "No Codes Found".
HELP.....
Thanks
Dec 27, 2007 at 5:29 PM
MERLIN2021
  • 17,250 POSTS
You may have a faulty ignition switch, or security problem. Turn the key to the on position, any lights? then go to acc position any lights? We want to see the check engine light!
Dec 29, 2007 at 8:19 AM
