1998 Pontiac Sunfire master cylinder
1998 PONTIAC SUNFIRE
RUSTY JORDAN
Brakes problem
1998 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
It has been a long time since i have replaced a master cylinder with this type of ABS setup. What I would like to know is how do I safely remove/reinstall the ABS control unit on the master cylinder if I do not have a TECH1 scanner to relieve the gear tension on the ABS motor pack? thanks for your help!
Jan 19, 2010 at 1:45 PM
BLUELIGHTNIN6
  • 16,542 POSTS
there is no safe way to do this repair until first using a TECH I or TECH II scan tool to release gear tension..
Jan 28, 2010 at 1:55 AM
