1998 Pontiac Sunfire just stopped working
1998 PONTIAC SUNFIRE
LAURAGOMO
Air Conditioning problem
1998 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
today after work got in the car and noticed the air conditioner was not working it worked 12 hours earlier and now it is just blowing warm air? What do I need to do?
Jun 12, 2009 at 7:51 PM
BILLYMAC
  • 2,204 POSTS
Hi Laura.. there is a couple of things you can check before you have to go to a mechanic.do this when the eng is off. unplug the plug at the ac compressor.plug it back in. try the a/c now still not working.turn car off. under the hood up near the back of the hood you will see a shiny aluminum canister. there is a plug here on the tank unplug it plug it back in. start car check a/ c. if no avail check all fuses.. if all good you will need someone qualified to check the refrigerant in the system.. hope this helps. if i can help please write back billymac
Jun 12, 2009 at 9:29 PM
