The blower is no longer forcing air through the vents. I checked the fuse in the drivers door panel (htr/blr?) and replaced the relay under the hood. I used a voltage tester to see if the blower was getting juice, and it wasen't; then checked if the leads going to the resistor where getting anything by setting the fan dial to different speed and putting the voltage prongs to ground and each wire individually, with no luck.
Does this mean the switch is bad (in the control panel in the dash)?
The a/c hasn't worked in a year, but tthe heateer hhas bbeen finne
Oct 14, 2009 at 10:26 PM
