1997 Pontiac Sunfire key stuck
1997 PONTIAC SUNFIRE
181,000 MILES • 4 CYL • FWD • AUTOMATIC
ZECHMEIBAUM
my key will turn the engine on but when i go to shut my car off the key will stick on accessories so i cant take my key out of the ignition it sticks in
Jan 5, 2008 at 9:57 AM
JSKELLY4693
  • 22 POSTS
I had a Cavalier that did the same thing! I had to replace the Ignition Park / Gear (might night be the right name)l line before it'd work again. Basically, it's a spring loaded line that is attached to the ignition and to the gear shifter. When you have your car out of park, it only allows you to turn the key back to accessories. Sometimes it can fall off the shifter.
This is a pretty hard process, as it involves tearing the dash and center console apart to get to it.
Recommended Way
You may need to purchase a Haynes Repair Guide at your local auto parts store.
A quick fix might be figuring out (and I can't remember how I did this) how to get the plastic cover off of the shift area (the dark grey plastic around the gear shifter, not the shifter itself) and just disconnect the line from the shifter, push it all the way in, and the key should work.
Alternatively, you can do the same at the ignition switch (i have instructions how to gain access to that
here https://www.2carpros.com/forum/1998-pontiac-sunfire-vt86618.html
Jan 13, 2008 at 12:07 AM
