1997 Pontiac Sunfire gas in oil
1997 PONTIAC SUNFIRE
178,000 MILES • 4 CYL • FWD • AUTOMATIC
CRAZYFACE
i am finding gas in my oil i found this out because i could see my gas gauge dropping fairly fast and the car will sputter in short quick bursts every 5 sec or so also i could not find any fuel leaks could this be a computer problem?{had computer flashed because engine light would not shut off} or could it be an injector problem????? thanx!!!
Dec 10, 2007 at 10:50 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I would pull the spark plugs and look for a very dirty, sooty spark plug, this will indicate a leaking injector the fuel is running down the bore past the rings and washing the protective oil from the bore , this will cause rapid ring deterioration so act quickly, if you find one faulty injector it would be wise to have all injectors serviced or replaced as a group.
Mark (mhpautos)
Dec 10, 2007 at 3:35 PM
