1997 Pontiac Sunfire Cooling fan isnt working
1997 PONTIAC SUNFIRE
197,000 MILES • 4 CYL • FWD • MANUAL
X6METAL6MOSHER6X
My cooling fan isnt working, uhm how do i get it running i've checked the fuse and the fuse is fine, and it has a relay switch how do i check to see if its bad? or how could i tell? other than that is there any other things that could be wrong with the fan?
Apr 26, 2009 at 11:06 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Link below will help you understand how to test a relay. .
http://www.2carpros.com/how_to/how_do_i_check_a_relay.htm
Does the cooling fan come on when the A/C is turned on? If not then the fan motor is probably faulty. If it does then it must be electrical so let me know how the relay test comes out..
Thanks for using 2CarPros.com!
Apr 26, 2009 at 11:27 PM
