1997 Pontiac Sunfire coolant leaks out of cap
1997 PONTIAC SUNFIRE
170,000 MILES • 4 CYL • FWD • AUTOMATIC
RUGERBYTES
1997 pontiac sun fire.only in the summer months for the past three years when i stop and shut the car off water or coolant will leak out of the cap on the overflow/ filler bottle on the firewall.the car does not over heat and the thermostat has been changed along with the water pump.the temperature gauge on the dash shows a normal reading.i have also replaced the cap on the filler neck. it leaks to the point where the container has no fluid left in it. could it be a possibility that the cap is not a o.e.m. part? the odd thing is during the winter there is no leakage at all. any input on this problem would be greatly appreciated.
thank you, Adam Charles
Sep 1, 2008 at 3:22 AM
2CARPRO JACK
  • 11,533 POSTS
Try an OEM pressure cap first. may be that when it is running at the proper temp, a lower pressure cap is letting coolant out into the overflow bottle.
Sep 1, 2008 at 7:48 AM
