1996 Pontiac Sunfire plugs and wires
1996 PONTIAC SUNFIRE
LEDZEPPELIN1234
Engine Performance problem
1996 Pontiac Sunfire 4 cyl Front Wheel Drive 129000 miles
how do you change the plugs and wires on a 2.2 liter engine
can detailed directions
Apr 10, 2010 at 8:15 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect the negative battery cable, and if the vehicle has been run recently, allow the engine to thoroughly cool.
Carefully twist the spark plug wire boot to loosen it, then pull upward and remove the boot from the plug. Be sure to pull on the boot and not on the wire, otherwise the connector located inside the boot may become separated.
Using compressed air, blow any water or debris from the spark plug well to assure that no harmful contaminants are allowed to enter the combustion chamber when the spark plug is removed. If compressed air is not available, use a rag or a brush to clean the area.
Remove the spark plugs when the engine is cold, if possible, to prevent damage to the threads. If removal of the plugs is difficult, apply a few drops of penetrating oil or silicons spray to the area around the base of the plug, and allow it a few minutes to work.
Using a spark plug socket that is equipped with a rubber insert to properly hold the plug, turn the spark plug counterclockwise to loosen and remove the spark plug from the bore.
WARNING
Be sure not to use a flexible extension on the socket. Use of a flexible extension may allow a shear force to be applied to the plug. A shear force could break the plug off in the cylinder head, leading to costly and frustrating repairs.
To install:
Inspect the spark plug boot for tears or damage. If a damaged boot is found, the spark plug wire must be replaced.
Using a wire feeler gauge, check and adjust the spark plug gap. When using a gauge, the proper size should pass between the electrodes with a slight drag. The next larger size should not be able to pass while the next smaller size should pass freely.
Carefully thread the plug into the bore by hand. If resistance is felt before the plug is almost completely threaded, back the plug out and begin threading again. In small, hard to reach areas, an old spark plug wire and boot could be used as a threading tool. The boot will hold the plug while you twist the end of the wire and the wire is supple enough to twist before it would allow the plug to crossthread.
WARNING
Do not use the spark plug socket to thread the plugs. Always carefully thread the plug by hand or using an old plug wire to prevent the possibility of crossthreading and damaging the cylinder head bore.
Carefully tighten the spark plug. If the plug you are installing is equipped with a crush washer, seat the plug, then tighten about 1 / 4 turn to crush the washer. If you are installing a tapered seat plug, tighten the plug to specifications provided by the vehicle or plug manufacturer.
Apply a small amount of silicone dielectric compound to the end of the spark plug lead or inside the spark plug boot to prevent sticking, then install the boot to the spark plug and push until it clicks into place. The click may be felt or heard, then gently pull back on the boot to assure proper contact.
When installing a new set of spark plug wires, replace the wires one at a time so there will be no mix-up. Start by replacing the longest cable first. Install the boot firmly over the spark plug. Route the wire exactly the same as the original. Insert the nipple firmly onto the tower on the ignition coil, and attach the wire separators to secure the wires. Be sure to apply silicone dielectric compound to the spark plug wire boots and tower connectors prior to installation.
Apr 10, 2010 at 10:09 AM
