Welcome to the forum, for the 2.2 litre engine, the ignition module is under the coil pack and looks like the picture.
Nov 29, 2009 at 3:05 PM
MARKGTZ2
MEMBER
where is the coil pack?
Nov 29, 2009 at 3:16 PM
MATTF87
MEMBER
If you get under the car, crawl back until you can see up through the motor a bit, just against the walls of the cab. You can actually follow the plug wires all the way to your coils. That is the Easiest way to find them.
