1996 Pontiac Sunfire w/140000 approx miles. The problem is the rear hazards do not work, but the front does. The turn signals work fine, both front and rear. In addition to that problem the horn does not work. There is an aftermarket alarm system installed and it still sounds through the horn. When the horn button is pressed the only sound is a clicking from the passenger's side below the dash. Removing the kick panel on the passenger's side to get a better look revealed very little. It appears that the fan for the heating and cooling is in the way of the relay that I hear clicking from there. I have replaced the relay behind the driver's side kick panel that supposedly controls the alarm, horn, and hazards, but that didn't solve anything. Aside from removing the alarm system and rewiring everything that they cut and spliced, I am out of ideas. Any help you could provide would be greatly appreciated.
Dec 30, 2006 at 6:28 PM
