1996 Pontiac Sunfire fuel injector
1996 PONTIAC SUNFIRE
75,000 MILES • 4 CYL • FWD • AUTOMATIC
CANDYMAN82176
  • 4 POSTS
i just replaced the orings on 1 fuel injetor and now when i try to start the car the #2 plug loads up with fuel. what can i do to fix it. it did not happen till i tried to fix the fuel leak on that injector.
May 12, 2008 at 4:10 PM
RHALL77
  • 3,361 POSTS
what do you mean it loads up with fuel.
May 13, 2008 at 8:04 AM
CANDYMAN82176
  • 4 POSTS
the firing end of the spark plug was covered in fuel. i found out that i had another leaking oring so i replaced them all. now i cant start the car. i think it may be flooded
May 13, 2008 at 11:20 AM
CANDYMAN82176
  • 4 POSTS
i have put in new plugs and it still turns over and tries to start.every once in awhile it will catch and run for a couple seconds. i am goin gto try to put in a new fuel filter and a new fpr to see if that helps. i am still looking for any other thoughts that it might be. Also was wondering but what if an oring fell into the hole and did not come out with the injector would that cause it not to run? i guess i am just reaching for anything at this time to get it running.
May 14, 2008 at 8:25 AM
RHALL77
  • 3,361 POSTS
are you sure you are getting fuel pressure?
May 14, 2008 at 8:54 AM
