1992 Pontiac Sunbird OIL LEAK AND SMELLS
1992 PONTIAC SUNBIRD
17,900 MILES • 6 CYL • 2WD • AUTOMATIC
SHELLIECARDINELL
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
THANK YOU!
Apr 28, 2008 at 5:19 PM
MASTERTECHTIM
  • 4,750 POSTS
the most common oil leak in this engine is from the oil pump drive o ring. its located under the throttle body at the top of engine block.
Apr 28, 2008 at 5:21 PM
VALCALDERA
  • 8 POSTS
Have you run some Injector Cleaner/fuel additive(s)?? ANY Engine sitting for that length of time will have Fuel gumming issues.
Even though the Rear Engine Seal may appear to be good, it can wither or shrink from the vehicle sitting for the length of time you stated thereby allowing Oil to pass.
Then as stated by mastertechtim you have an upper engine oil leak as you will constantly have an "oil burning off the engine" problem.
Sep 14, 2008 at 1:00 PM
