1992 Pontiac Sunbird Engine Overheating
1992 PONTIAC SUNBIRD
23,000 MILES • 4 CYL • FWD • MANUAL
TREVOR SPENCER
  • 8 POSTS
last night i was driving home from work and i noticed that my temp gauge indicated my engine was getting way too warm, like, i wasnt at the overheating mark, but it was above the 3/4 line. i had to walk home because i didnt want to warp the head.
this mornin i went out to check what might be wrong, i started looking at the rad (if this makes any difference i brought it to a shop yesterday to have the spouts soldered.) and i seen TINY TINY drops coming from the bottom rad hose, but it wasnt really dripping from the engine. it was just sitting there, i wiped it off and started to look elsewhere. i felt the hoses that are for the heater core, the one going from the engine is hot and other is kind of warm. so my dad and i think that my heater core might be plugged up...but not sure
driving it around a little today testing things, i noticed also the top rad hose is hot, like i can burn my hand if i hold too long, and the bottom rad hose is cold...
thanks for help in advance
Dec 16, 2009 at 3:14 PM
Have you ever flushed the radiator? Have you replaced the thermostat?
PS: The heater core won't cause the engine to overheat.
Mar 8, 2010 at 10:44 AM
TREVOR SPENCER
  • 8 POSTS
hey thanks for replying but the problem was resolved... the temp gauge is just kinda screwy, thank you anyways
Mar 8, 2010 at 3:17 PM
I'm glad you got it taken care of. Let us know if you have questions in the future, and thanks for using 2carpros.com.
Mar 8, 2010 at 5:33 PM
