1991 Pontiac Sunbird Wont crank
1991 PONTIAC SUNBIRD
MALCOLM4070
Electrical problem
1991 Pontiac Sunbird 4 cyl Front Wheel Drive Automatic
Car has sat for a year, battery is dead. used to run, when i jump it accesories come on strong but wont crank just clicks. Whats likely problem?
Oct 25, 2009 at 8:55 PM
JDL
  • 16,098 POSTS
Welcome, I'd make sure the battery has a full charge and the connections are good. You may need to pull the plugs and belts, see if you can turn the crank by hand? Sounds like not enough voltage to run the starter?
Oct 25, 2009 at 9:30 PM
OBXAUTOMEDIC
  • 3,711 POSTS
First things I would do....
Check Positive Cable remove and clean
Check connections on starter, remove and clean.
Check Ground Cable connections at both ends remove and clean.
If after making sure all connections are clean and tight, you still get clicking then remove starter and take to local parts store and have them test it.
Mark S
Oct 25, 2009 at 9:33 PM
