I have a 91 Pontiac Sunbird that is giving me much trouble. The car was driving fine and all of a sudden died on the hwy. When I tried to restart it, it would crank and kinda act like it wanted to start but would not. The car will run like a champ if I spray starting fluid in the intake, but will not run once I stop spraying.
I've changed the Ignition Module, Coil packs, plugs, wires, cam position sensor, knock sensor, fuel filter and it still acts the same way. When I check for fuel pressure at the fuel rail I show 40 psi. Using a noid light I know I have a signal at the injector. I have good spark all the way around. I've taken the fuel rail assembly apart and cleaned it entirely. Each injector was removed and new O rings where applied. I know that atleast 2 injectors were pumping fuel as I did not get them entirely back in place and they were spraying fuel.
Anybody who may be able to help I'd appreciate it. This has me frustrated to no end. Thanks in advance.
Oct 20, 2008 at 10:16 PM
