well here is the problem.... pump does not prime the system or come on at all when i turn the key on and while cranking the engine.... heres what i have tried.... new distributer cap module rotor plug plug wires new engine computer... i know it is not the pump as i pulled a fuel line off the TBI and used the test lead to run the pump... there is fuel comming out of the line... i checked the relays as well tested the coils and the relays seem to work just fine (it clicks then there is continuity) there is a green wire that comes fro m the enginge computer under the dash to the relay and it does not seem to get any power... also from this relay i can make the pump run... so here is what i think i narrowed it down to... the pump is fine... the relays are fine... the computer is fine... but what ever is telling the computer to prime the fuel system and run the pump is not...
May 6, 2006 at 3:36 PM
