1990 Pontiac Sunbird won,t crank
1990 PONTIAC SUNBIRD
134,000 MILES • 4 CYL • FWD • AUTOMATIC
YENDOR57
car just die while going down road ,checked timing, replaced wires, plugs distributor cap & rotor button coil, fuel injector, brain (Computer) , engine will turn over, but will not even try start, PS after only a few seconds there is a strong smell of gas, have spray starting fluied still nothing.can u help
Jan 24, 2010 at 9:00 PM
It sounds like you are not getting spark to the engine. Have you checked the crank sensor? Ignition module... Has the check engine light come on?
Let me lknow.
Mar 8, 2010 at 7:57 AM
