Wiper Motor Problem
PONTIAC
PURPLEPACKFAN
Hi
I'm new to this forum out of desparation or frustration, not sure.
Car-2000 Pontiac Trans Am
5.7 L 305 hp 6 speed, 74000 miles
Problem: Wipers not going to PARK position when shut off. Replaced motor unit with remanufactured motor. Now when the wipers are shut off, they go to the proper PARK position. NOW when you run the wipers in "intermittent" position every time they stop they are in the up position, right in front of your face. I got another motor unit and tested it and I get the same response.
Is it in the circuit somewhere? Did I get two defective motors? Any ideas???
Jun 9, 2007 at 10:55 AM
SERVICE WRITER
  • 9,123 POSTS
Turn the ignition switch to the on position. Turn the wiper switch to the off position. Disconnect the wiper switch connector. If the wipers park, replace the switch. If not update the post.
Jun 9, 2007 at 12:09 PM
