old starter works but you have too turn the key a few times , you can hear the solinod click each time you turn the key ,then the starter ingauges and the car starts,, problem is .i replaced the old starter with a brand new one, now when you turn the key you dont hear the solinoid ingauge but also the car doesn't start, took the new starter off put the old one back on and and with a few trys the starter works, new starter was tested and works , i was told that the starter relay might be the problem , or the ingnition switch. i was told that the old relays are worn out, but my problem is i dont know where the starter relay is , or the ignition switch is located. could this be my problems .
Sep 9, 2006 at 5:43 PM
