Pontiac GTO, 1967, newly rebuilt 400 with less than 2000 miles. I was wondering if someone might have any ideas as to a knocking sound coming from the motor. I have not been driving this car as it's in the process of restoration. I have been starting it up to let it run, but that's about it. Hasn't been run on the road for about 2 months, I didn't have any problems until the other day I stated it up, backed it into the driveway and shut it off. Started it back up again, the timing slipped it backfired and a knocking sound started. I reset the timing and checked my carb. The distributor is new and I pulled it to check it, the points are fine, it has no wear. The sound to me seems like it is in the rear of the motor. I checked the flywheel and torque convertor to make sure they are tight and they are. When it's put in gear the knocking gets worse and it stalls out. :roll: I would be so grateful if somebody might have any other suggestions. Thank you for your help.
Sep 22, 2007 at 9:50 AM
