95 Pontiac Bonneville SE - Dashboard Oil Pressure Display
1995 PONTIAC
CARREPAIRQUESTIONS
2CarPros.com
Subject: 95 Pontiac Bonneville SE
Mileage: 184941
Engine Type: 3800 Series II – V6 Engine
Problem[s]: Dashboard Oil Pressure Display descends and displays the indicator needle in the red zone whenever the car is stopped/paused at a red light... and or sometimes when the car is on and in the park position. However, when the car proceeds at virtually any speed it correctly adjusts to readout of 40.
Problem: Antilock brake light occasionally appears on the dash and remains neither lit and despite any need nor use of such braking system/solution to be required.
Problem: Freon level in and versus air conditioning/cooloing system shows as full....blower is fully operational furthermore...yet no cold air is being forwarded through....
Jul 18, 2007 at 10:00 AM
2CARPRO JACK
  • 11,533 POSTS
Oil pressure- Install a manual pressure gauge to verify pressure at low engine speeds and at idle. Could be a faulty gauge or sending unit
ABS-Have it scanned to see if it stored any trouble codes.
A/C- Safe to assume a/c gauges were installed to verify system pressure? Does the compressor cycle on?
Jul 18, 2007 at 2:46 PM
