Here's the symtoms/problem:
1. Very little heat coming from the vents at idle or low RPM after car is at operating temperature.
Normal heat (or close) when operating at higher RPM's
2. Engine is operating in the normal temperature range. (Not too cold or too hot)
3. Was about 1/2 gallon low on anti freeze. (Replaced to required level)
4. While engine was operating at various RPM's could not see movement of water when viewing in the radiator cap.
5. Oil does not appear to be contaminated and have not smelled or seen coolent coming from the exhaust.
Sep 25, 2008 at 9:03 AM
