1995 Other Pontiac Models Ignition Not Turning
1995 PONTIAC
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
FRANK G
This Car Would Not Start. I Replaced The Starter. Car Started Right Up I Let It Run A While Drove Around The Block, Parked, Shut Off. Minutes Later When I Went To Start Again. Nothing Happens Doesnt Turn, Will Not Crank. A Friend Looked At It He Jump Started The Starter And It Starts. Still It Wont Stat from The Ignition. Battery Is Fine I Had It Tested
Apr 10, 2008 at 8:34 AM
BLACKOP555
  • 10,386 POSTS
sounds like a bad ignition switch, or a bad starter relay, since it isnt engaging the starter.
Apr 12, 2008 at 1:09 PM
