Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Pontiac
Other
Engine Cooling
Water Pump
Replace/Remove
1995 Other Pontiac Models How do you replace a water pump my
1995 PONTIAC
166,000 MILES • 6 CYL • 2WD • AUTOMATIC
BLUEDOGER_79
MEMBER
1 POST
FOLLOW
the water pump is leaking fluid but im unable to tell were
Mar 25, 2008 at 7:30 PM
MMPRINCE4000
CERTIFIED EXPERT
There is a small "weep" hole in the casting, if the seal goes bad it will usually leak from there first, assuming it is not a hose or clamp.
Mar 31, 2008 at 7:22 AM
