Heater problem
1991 Other Pontiac Models V6 Front Wheel Drive Automatic 200000 miles
Good Day,
HISTORY: I have a 1991 Pontiac Tempest (3.1L) that I'm having overheating problems with. At first, it was leaking antifreeze. The car wouldn't blow heat, but the fan worked. When I turned the fan on, there was a sickly sweet smell. Although it was a pain to keep filling the antifreeze (the resevoir would run out about every 2-3 days), at least my car wouldn't overheat. I figured I probably needed a new heater core. However, I've since found that when my engine was recently replaced (about 2 weeks before I noticed my antifreeze leaking), a line was cut near my firewall and repaired with clamps. So now I'm not sure if I simply need to replace the clamps properly or if my heater core really does need to be replaced.
At any rate, the antifreeze stopped leaking and my car began to overheat quite quickly. The resevoir is still full, but the antifreeze isn't being drawn out of it. I was told that there may be an airlock from my antifreeze running out before, and to run my car with the rad cap off for a bit to try and push out air. I tried this, but it didn't help. I then replaced my thermostat, thinking it may be stuck close (and cheap part/easy to replace anyways). This hasn't helped either. I asked another person to take a peek at my car (handy with vehicles, though not pro mech or anything). We tried putting antifreeze directly into my rad to see if it would stop the car from overheating. I'm not sure how he was able to tell, but the guy said that the antifreeze wasn't circulating. He also mentioned that a seal (just down and to the left of my thermostat) needs replacing as antifreeze was bubbling near there.
So, I'm now wondering if perhaps I need a water pump if my antifreeze isn't circulating??? Once I can get my antifreeze/coolant to start circulating again, I will replace the clamps and seal I mentioned. If that doesn't fix the leaking issue, should I replace my heater core? Or is there something else I should investigate first?
Also, there has never been any smoke if that info helps at all. I've never really noticed any obnoxious sounds either. It revs low sometimes, but I think that was from condensation in the fuel lines and I haven't noticed that problem again since using gasline antifreeze. Thought I'd mention just in case, though.
Cheers!
Trinity
Good Day,
Cheers!
Trinity
Dec 10, 2007 at 5:37 PM
