The only difference between a Pontiac 350 and a 455 is that some Pontiacs engines and distributer and shaft run counter-clock ways aslong as you don't use the distributer or shaft on the 455 you will have no problems your transmission and hanger will fit like a glove. And you're #1 piston might be on the other side of the 350 . look on your intake manifold of the 455 to get the proper fireing order . one last thing is to meassure you're drive shaft it may be alittle shorter , but if you got alittle play and it doesn't fall out of the trans then you're good to go have fun with you're project. Adam Przybyszewski ( Poleski ) (;
Jun 11, 2009 at 10:01 PM
