3.4 intake gasket
PONTIAC MONTANA
4SPDGOAT
99 Pontiac Montana 3.4 with 118,000. Replaced the intake gasket due to leaking. Also replaced spark plugs thermostat, hoses and changed the oil, etc. while it was apart. Went together fine, started up and ran great with no noises or leaks of any kind. Drove it about about 10 miles that night. On the way to work the next day it drove great for about another 10 miles then suddenly it started missing badly and making a ticking noise. The noise sounds like upper valvetrain from the rear bank. It increases with engine speed, and the van has no power at all. It acts just like a mis-fire.
update: I hooked up a scanner to read codes, and there is no power at the DLC connector. Any ideas where to look for a cause like this? thanks!
Thanks for the reply! I could not locate a bad fuse to the DLC, so decided to use a jumper wire with a 5amp fuse and backprobe the connector to supply 12v. It worked-powered up the scanner, read code (#2 cyl mis-fire). Problem was loose rocker arm. Re-torqued and all is running well so far. I was not able to pinpoint the noise from the stethlescope, but pulling the plug out to see it was fouled verified the cyliner location.
Jul 20, 2006 at 9:27 AM
SERVICE WRITER
  • 9,123 POSTS
First check the fuse for the aldl connector-probably the same as the cigarette lighter.
Second, When the intake gasket goes on those, different problems can happen. It can push out coolant or oil, suck in coolant or oil or mix them. My guess is it may have mixed them but also sucked out oil. The lower end of the engine has probably spun bearings. The noise source can be deceiving.
Jul 25, 2006 at 7:02 PM
