2004 Pontiac Montana Interior lights not working
2004 PONTIAC MONTANA
121,000 MILES • 6 CYL • FWD • AUTOMATIC
DEB13173
The arm to our sunvisor on the passenger side broke. We removed the visor and the interior lights stopped working. We replaced it with a new one and the lights still are not working. I checked the manual switch on the overhead panel and it is ok and the fuse seems to be ok. What could be wrong?
Oct 8, 2008 at 3:18 PM
DAVIDC
  • 5 POSTS
Re check the fuses, sounds like if it worked before you may have pinched a wire in the headliner. Also, does the map lights work? Did the visor have a light on it and does the lights work from the dimmer switch?l This may help narrow down the problem. quote="deb13173"]Interior problem
2004 Pontiac Montana 6 cyl Front Wheel Drive Automatic 121000 miles
The arm to our sunvisor on the passenger side broke. We removed the visor and the interior lights stopped working. We replaced it with a new one and the lights still are not working. I checked the manual switch on the overhead panel and it is ok and the fuse seems to be ok. What could be wrong?[/quote]
Oct 10, 2008 at 8:06 PM
