2004 Pontiac Montana brake ligths stuck on
2004 PONTIAC MONTANA
191,000 MILES • 6 CYL • 2WD • AUTOMATIC
PAT12312
my brake ligths are stuck -----pull the fuse & they stay on--------
Jun 20, 2010 at 9:05 PM
BLUELIGHTNIN6
  • 16,542 POSTS
pulling the fuse has to disconnect the brake light's circuit so obviously you're not removing the correct fuse. the main issue is most likely a faulty brake light switch though.
Jun 20, 2010 at 9:35 PM
PAT12312
[quote:d288cc9625="bluelightnin6"]pulling the fuse has to disconnect the brake light's circuit so obviously you're not removing the correct fuse. the main issue is most likely a faulty brake light switch though.[/quote:d288cc9625] i did take out the rigth fuse --there is a short somwhere ---- it something to do with my keypass ------ the fuse there was blown & my warning ligth was on !! when i put a new fuse in the brake ligths come on & stay on until i remove the fuse -
Jun 22, 2010 at 12:18 PM
