2004 Pontiac Montana
2004 PONTIAC MONTANA
WPG45
Brakes problem
2004 Pontiac Montana 6 cyl Two Wheel Drive Automatic
I have a warning light that is not explained in the manual. The picture is in the red screen. It is a Circle with a small bump on top and bottom. There is a jaged line through the circle and there are brackets around the circle
Jan 13, 2009 at 5:06 PM
SERVICE WRITER
  • 9,123 POSTS
This is what I get from the description.
https://www.2carpros.com/forum/automotive_pictures/30961_Image1_5.jpg
The only thing that comes to mind that has a jagged edge is a low tire light... Can you post a pic.?
Jan 13, 2009 at 6:19 PM
WPG45
I figured it out , it was low brake fluid indicator. Once I fill the master cylinder it went away
Thanks for your help
Jan 13, 2009 at 10:10 PM
SERVICE WRITER
  • 9,123 POSTS
No problem...Too bad I didn't do anything!
Jan 14, 2009 at 5:44 PM
