2003 Pontiac Montana Front bearings
2003 PONTIAC MONTANA
13,000 MILES • 6 CYL • FWD • AUTOMATIC
TODD MORRIS
How difficult is it to change the bearings on this type of vehicle; Is the bearing needed sealed or not and should I change both on the front and finally are there special tools needed. Thank you very much, Todd Morris
Mar 25, 2008 at 4:07 PM
BLACKOP555
  • 10,386 POSTS
i believe your wheel bearings may be pressed in, contact a auto part store and ask if its pressed in bearings or if it is removable, if its pressed in you need to have a shop do it for you, if not you can do it yourself with some basic tools.
Mar 25, 2008 at 7:36 PM
