Engine Mechanical problem
2002 Pontiac Montana 6 cyl Front Wheel Drive Automatic
My starter appears to have a bad spot. It will click occasionally and not turn over. This sounds dumb but if I open and drop the hood closed it will eventually catch and start normally several times,then I have to repeat the procedure. I fear I will be stuck somewhere when it will not respond to this method. I want to replace the starter and wondered what the proper procedure is. Thanx Skip
Jul 27, 2009 at 7:13 AM
