Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Pontiac
Montana
Ignition
Spark Plug
Replace/Remove
2002 Pontiac Montana replace rear sparkplugs
2002 PONTIAC MONTANA
80,000 MILES • 6 CYL • FWD • AUTOMATIC
SAL SCELISI
MEMBER
1 POST
FOLLOW
can i use a jack under oil pan to rotate engine forward,after removing the two mounts above radiator thank you
Jun 23, 2008 at 8:58 PM
DENNYP
CERTIFIED EXPERT
Be sure to put a block of wood under the pan first. Make sure it's not directly in the center of the pan.
Jun 24, 2008 at 4:20 PM
