2002 Pontiac Montana Brake light came on while driving and
2002 PONTIAC MONTANA
160,000 MILES • 6 CYL • FWD • AUTOMATIC
SHARON3360
MEMBER
FOLLOW
While driving home my brake light came on and an indicator light with wavy sign in parintheses came on what does this mean?
Sep 1, 2009 at 10:41 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
check your brake fluid level and let me know how it is
Sep 1, 2009 at 10:53 PM
SHARON3360
MEMBER
brake fluid was low.. thank you
Sep 1, 2009 at 11:22 PM
HCROTTY
MEMBER
I have a 2003 Pontiac Montana with the same problem. I have put brake fluid in it and the lights still won't go off. Is there any other reason for this?
May 5, 2010 at 7:44 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
is it the ABS light or the yellow brake light thats on? do you have any trouble with braking?
May 5, 2010 at 8:26 PM
HCROTTY
MEMBER
It is the brake light and another one in the shape of a circle with a wavy design inside the circle.
May 6, 2010 at 6:13 AM
BLUELIGHTNIN6
CERTIFIED EXPERT
For the brake light, make sure the e-brake is fully released and the master cylinder is full of fluid. You should be able to read ABS codes with a professional scanner, but my guess would be a faulty ABS sensor
