2001 Pontiac Montana high idle
2001 PONTIAC MONTANA
109,000 MILES • 6 CYL • FWD • AUTOMATIC
JOYROADBOY
hi i just replaced head gaskets on my van, had heads cut and checked before replacing. ok so i finished the job and the van ran fine until i test drove the van i drove around the corner and back by the time i got back around corner the van began to idle very high in drive like around 1300 rpm once in park van idle was 2900. i checked the tps sensor and was within specs, sprayed carb cleaner around intake to ckeck for vaccum leaks no change in idle. i tried un-hooking battery for 5 min but same thing after hooking back up. any suggestions would greatly be appreciated
Oct 14, 2010 at 7:41 PM
Try cleaning out the idle air control valve and see what happens
Oct 14, 2010 at 8:25 PM
