2001 Pontiac Montana Brake caliper not releasing
2001 PONTIAC MONTANA
DELAY
Brakes problem
2001 Pontiac Montana 6 cyl Front Wheel Drive 175000 miles
The caliper on the passenger side front is still not releasing, sometimes, even after having a professional replace the calipers, rotors and brakepads.
Mar 28, 2010 at 1:44 PM
Chances ar the rubber brake hose going to the caliper is bad. They deteriorate and allow fluid to pass one direction and not the other. What to do is this. Remove the tire from the vehicle and pump up the brakes until the rotor won't turn when you release the brake pedal. If it sticks, open the bleeder valve. If pressure comes out and the caloper releases, replace the hose.
Let me know what you find.
Apr 25, 2010 at 12:34 AM
DELAY
I had the hoses replaced at the same time I had the calipers replaced. What solved the problem was a new master cylinder. The old cap had a rubber diaphram that attached to it. For some reason it got sucked down in the master cylinder and was causing the problem. Sometimes it was stopping the flow of fluid and sometimes it wasn't. Thanks for your help and advice.
Apr 25, 2010 at 1:02 PM
I'm glad you got it fixed. Let us know if you have questions in the future.
Apr 26, 2010 at 10:28 AM
